I have a ZZr1400with an ihi turbo on it,I have had the bike running but not very well.
Tonight I rechecked the fuel pressure as coming off the rising rate regulator i was only seeing 50lbs max pressure.
I went straight off the pump outlet and dead headed the pump still shows only 50psi.
The pump is a Gs342 should be good for 90psi and 255lph.(I believe) but as i say only shows 50psi.
I suppose the next move is to remove the pump and check it at straight out of the pump.
I believe the standard regulator is in the tank......Is this modded?
I would assume so as it would only ever make 42psi or so does anyone know the mod ??
I changed the in tank pump as above but didnt do anything else....any ideas
Romans we had a bit of dialogue on this recently do you have any clue?
Cheers
